Drilling and tapping stock intake manifold
Old Mar 11, 2006, 10:30 AM
SlowCar's Avatar
Just wondering anyone here has tried drilling/tapping the stock intake manifold....wondering if the cast aluminum will tap well.
It will be a real fine thread, M8 X 0.75.
Old Mar 11, 2006, 10:42 AM
denial's Avatar
are you planning on setting up a 4 port WI system per chance?
Old Mar 11, 2006, 10:52 AM
SlowCar's Avatar
lol! you read my mind
Old Mar 11, 2006, 11:54 AM
denial's Avatar
nice! man, how are you going to monitor each of the jets? Don't tell me you're going to buy 3 flow meters...
I don't have any direct experience tapping cast Al, so I can't really help you there. Easier to tap than cast iron, but at the same time be a bit more delicate perhaps?
you better post some pics when you've got this setup worked out!
Old Mar 11, 2006, 12:04 PM
SlowCar's Avatar
thru the aquamist dds3. i'll set the window of operation - too high flow = leak, too low flow = one or more jets clogged. anywhere outside the set flow, the system will not allow boost to build above wastegate - ~12psi on stock WG.
91 octane here in tucson is just no fun
Old Mar 11, 2006, 12:14 PM
C6C6CH3vo's Avatar
If you screw up and need an extra stock IM with all the lines, sensors, and solenoids and TB still intact, GSC has one but for about $200
drewblueeye
38
May 6, 2012 12:16 AM
IndyCar03Evo
18
Mar 1, 2012 05:53 PM
omniprobe
Jun 6, 2011 01:10 PM
Sap12687
Jun 11, 2007 11:41 AM
BoostWhore
Aug 28, 2005 08:23 AM
Quick Reply: Drilling and tapping stock intake manifold
