Transmission failiure
Old Mar 26, 2003, 11:33 AM
limey's Avatar
1000 miles and my evo is in the dealer with them reporting they found a ton of metal in the trans oil and casing...my question is what now on a car a week old......what would you want Mitsubishi to do? It has had very light use and I have been babying the thing....obviously a fault from new
Old Mar 26, 2003, 11:35 AM
uranium9v's Avatar
They need to replace, not fix. It's obvious something went wrong there.
Old Mar 26, 2003, 11:38 AM
limey's Avatar
Thanks I need to mark the casing or grab the numbers or something
Old Mar 26, 2003, 11:39 AM
HobieKopek's Avatar
Probably a manufacturing defect. Some people get all the luck, eh? Sorry to hear that.
Old Mar 26, 2003, 11:41 AM
uranium9v's Avatar
yeah...make sure they don' tjust try to fix it ..... mark it or something.
limey's Avatar
I am now worried about the front diff ect....does the center diff run off the trans oil? does the front diff run off the trans oil?
Old Mar 26, 2003, 11:42 AM
nyclancer's Avatar
I'd demand a new one.
Old Mar 26, 2003, 11:43 AM
limey's Avatar
A new car?
Old Mar 26, 2003, 11:45 AM
Crzylizard's Avatar
at the very least a new tranny
Old Mar 26, 2003, 11:48 AM
number13's Avatar
I thought I was the only one! Dealer said Mitsu has never heard of bad trans in evo. Mine only had 380 miles when it started whining. I hadn't thought that the front diff might share the same oil and shavings. They want to just replace the bearings.
limey's Avatar
I guess I loose the best break in method bet proven not to work!!!
Old Mar 26, 2003, 11:49 AM
stvbreal's Avatar
Re: Transmission failiure
How did you know something was wrong? Noise?
Old Mar 26, 2003, 11:50 AM
limey's Avatar
This could br the tip of the iceburg....there was another member on here complaining of a diff noise maybe ....my noise started around 500 miles
Old Mar 26, 2003, 11:53 AM
stvbreal's Avatar
That was me with the diff noise. I get it when downshifting at higher RPMS. A grinding noise almost. But only when I let up off the gas Winding down from say 6k to 3k it makes a loud grinding noise then stops after 3k back down to 0.
Quick Reply: Transmission failiure
