EVC V boost controller - problems with boost spike ??
Old Mar 25, 2003, 12:12 AM
Alfriedesq's Avatar
I just got done with my first test spin with the HKS EVC V installed - I have the JDM version with Kpa read out
I am having terrible boost spike
I have it set to SWNG type wastegate and the volume is on 14 - it spikes up to like 20 PSI right away and then falls back to about 13 - 14 psi
Did anyone else install one of these boost controllers yet? Am i doinmg something worng ?
Is this boost controller N?G for our cars ???
Any advice would be appreciated
PS - check your intercooler hose clamps on the junction near the battery - I blew mine off and got stuck on the side on the interstate - it was fun to re-attach and re-set the ECU with all those trucks blowing by me at 12:30 in the a.m .
Old Mar 25, 2003, 05:59 AM
Turboniam's Avatar
Re: EVC V boost controller - problems with boost spike ??
I know the feeling
Old Mar 25, 2003, 10:16 PM
Alfriedesq's Avatar
My reserach is possibly indicating a issue with the restrictive exhasut and the twin scroll building boost too quickly - or maybe I am completely Polish and hooked up the boost controller wrong >?
Old Mar 25, 2003, 10:37 PM
liquidlancer's Avatar
hmm dun no your problem but ill buy your evc v if you decide to sell it :-)
Old Mar 25, 2003, 11:24 PM
Alfriedesq's Avatar
That may be comming soon - I'll let you know - I have one or two more angles to test then i am getting rid of it !
Old Mar 26, 2003, 03:55 AM
evo_dan's Avatar
Something that can sometimes cause this is a boost leak somewhere in the line. Check all your lines and the boost controller to make sure your not leaking boost somewhere, including from your boost gauge if you have one.
Old Mar 26, 2003, 11:14 AM
Alfriedesq's Avatar
Re: Re: EVC V boost controller - problems with boost spike ??
Thanks man - thats what it was - a minor leak in one of the hoses ! Now it works nice - - still has a very slight bump in boost at about 4,000 then it settles down nicely and holds flat to red line - the HKS unit is very very good - also - I took off the rear muffler to see how that helped - not much
Old Mar 27, 2003, 12:14 AM
VOLSBimmer's Avatar
Is this BC on your EVO 8 already or your STI?
If it's on your EVO, how was the install?
Old Mar 27, 2003, 08:43 AM
Alfriedesq's Avatar
EVO - actually the install was quite hard a sthere is very limited space under the hood
Old Mar 27, 2003, 10:59 AM
VOLSBimmer's Avatar
I understand where you're coming from w/ the limited space issue, I helped my brother install an HKS boost controller on his old Stealth twin turbo, and those things have NO space under the hood, it's hard to even stick a finger in there!
So did the BC for your EVO come with instructions, or did you just basically figure it out yourself?
prEVOke
Oct 20, 2015 01:31 AM
v2lab
Aug 17, 2014 10:17 AM
ghad
May 25, 2014 02:27 AM
Evo Tengoku
97
Mar 24, 2014 09:13 PM
BEISSEN
Dec 4, 2010 02:57 PM
Quick Reply: EVC V boost controller - problems with boost spike ??
