which plugs for 100% methanol?
Old Dec 7, 2005, 06:11 AM
Derek888's Avatar
I just got my car tuned for 100% methanol on stock turbo/ignition with fully built race head and 272's boosting 26psi. I did a search on spark plugs and seems like most are using the 1 step colder ones which is the NGK BPR8ES gapped at .022? Some said the BPR8ES work good but the life span on it isnt that great and some had better luck with the Denso IW-24 that lasted much longer than the NGK's. Trying to gather some information on what plugs everyone is running with alcohol injection....
1.Which plugs are you using?
2.How much boost and gap?
3.Life span on the plugs?
Thanks!
Old Dec 7, 2005, 06:46 AM
joeymia's Avatar
I have been using NGK BR8EIX plugs. A little more costly than copper plugs but they seem to last longer. On the stock ignition I was using .22 gap but know I gap them to .30.
Old Dec 7, 2005, 07:07 AM
SwiftEVO's Avatar
I use the bpr8es gapped at .022 with stock ignition. I change them about every 5k miles. I would just stick with those. Sure you change them more often but they are only 1.50 each. Beats 10-12 bucks for the iridiums.
--Josh
Old Dec 7, 2005, 07:13 AM
Ev0ikon's Avatar
Yup. BPR8ES gapped to 0.023" here and let her spike to 30 PSI. She's still boosting strong for almost a year and I pray for her everyday. :}
I change my plugs every 3K miles with my oil and tire rotations.
Old Dec 7, 2005, 07:14 AM
platinumspecv's Avatar
With using methanol and high boost (stock ignition), you -should try the bpr8es. Also think about the HKS DLI-2 Ignition amplifier... some Evo's misfire at high boost...this will help a lot.
Old Dec 7, 2005, 07:17 AM
Derek888's Avatar
where can I find the NGK plugs at 1.50 online?
Old Dec 7, 2005, 07:19 AM
joeymia's Avatar
--Josh
i pay 7 dollars for my plugs
http://www.ngk.com/results_cross.asp...R8EIX&kid=2526
I usually like to have 2-3 sets around. I tried copper and went thru like 2-3 plug sets fairly quickly.
Old Dec 7, 2005, 07:25 AM
Your local parts store will have them. Try Napa
Old Dec 7, 2005, 07:49 AM
Derek888's Avatar
fairly quick? 1 or 2 months..how many miles if you could remember?
Old Dec 7, 2005, 08:13 AM
kmcconn9's Avatar
for those of you using meth/alcohol and dli2, what plugs/gap are you using??
Seems to be still the bpr8es gapped anywhere from .022-.030..
Old Dec 7, 2005, 08:26 AM
ArchieBabes's Avatar
Using NGK BPR7EIX plugs gapped at .23 using HKS DLI 2 and boosting 30psi 400whp 410wtq
11.8@122mph
Old Dec 7, 2005, 08:34 AM
VTECH8TR's Avatar
Moving to correct forum.
kmcconn9's Avatar
/\ who tuned your car?
Old Dec 9, 2005, 12:26 PM
Chris@nolimitmotors's Avatar
I used NGKBPR8ES gapped to .028 with the HKS box. the other guy here and 2 of my customers were using same plugs gapped to .022 with stock ignition.
Deanooo
Aug 25, 2016 05:17 AM
Evo47
Apr 10, 2016 01:00 PM
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
Gary@MellonRacing
Mar 18, 2009 05:58 AM
berkel
51
Apr 7, 2006 08:54 AM
Quick Reply: which plugs for 100% methanol?
