Signs of a bad front diff?
Old May 7, 2005, 04:54 PM
j-evo8's Avatar
I have been complaining about a "howling" noise on the front of my car. I have it up on the lift right now. I get 1.25" of play when moving the drivers side tire before the pass side moves. I get 2.25" of play on the pass. side before the drivers side tire moves. Is this a bad front diff? Any help would be great. Thanks!
Old May 7, 2005, 04:58 PM
redevo561's Avatar
Jack the car up so both front tires are in the air and turn the left wheel and the other right wheel should turn the opposite way if not then your front diff might be having some problems
Old May 8, 2005, 09:38 AM
GEARS's Avatar
If this an 05 EVO it will have a helical limited slip front differential and due to the nature of the design, how much backlash there is between the two front tires will vary a little over the life of the unit.
Jon@teamrip.com
Old Jul 6, 2005, 06:27 PM
TheGuyUpstairs's Avatar
Lightbulb Broken Front DIFF...
Hey If You Have A 2003-2004 EVOLUTION I Have A Diff In Perfect Condition Only About 2,000 Miles On It Before Got The Quafe Upgrade Let Me Know I Can Help You Out
Old Jul 6, 2005, 06:30 PM
hkfeet's Avatar
I got a stock diff for sale too, lol check my sig
Old Jul 6, 2005, 06:33 PM
j-evo8's Avatar
Funny how this thread comes to life.
I still have the same problem. Just had my transfer case replaced under warranty (what a pain that was). Just got the car back after it being down at the dealership a month. Two days later, everytime I turn under throttle, I'm getting a metallic sound and the front of the car feels like it is binding up. Also, sometimes when downshifting into 2nd when coming down a hill, as I let the clutch out (exedy twin), the front of the car starts to hop. Anyone have any ideas?
*Note: Driveshaft and rear diff were also replaced becuase the dealership wouldnt believe me that the TC was the problem.
** ALSO - can someone tell me where the front and center diff's are? I have read far to many conflicting threads. Some say TC and some say left and right of the tranny.
2005 Evo with under 10k on it.
Old Jul 6, 2005, 06:46 PM
Lightbulb Diff In The Front
The Front Diff.. Is In The TC... I Know For Sure I Used To Hang Out At Road Race Enginering All Of The Time And Is Where I Got My Work Done(The Best Evolution Shop Ever)... The Only Way That Your TC Will Be Destroyed Is From A Broken Front Diff. When The Diff. Breaks The Peices Of The Broken Diff. Shoot Around In The TC Ripping The Inside To Pieces
Old Jul 6, 2005, 06:48 PM
j-evo8's Avatar
If not a front diff, then the center diff? Im running out of ideas. The TC has ~150 miles on it since it was replaced. HOWEVER: the tech filled the TC up with the fluid for the rear diff, not the standard TC fluid. They just swapped that fluid out today and put in the correct stuff. ANYONE have ANY ideas?! Ive been without my car for over a month.
Old Jul 6, 2005, 11:07 PM
titaniumkingpin's Avatar
your dealership put rear diff fluid in your TC? how long did you ride like that for?
Old Jul 7, 2005, 08:06 PM
ebbeast2005's Avatar
my car wines real loud when i down shift what is this. ive allready had tranny rebuilt (stock)
Old Jul 7, 2005, 08:20 PM
ThEHiTMaN's Avatar
Mmmm I read alot of these threads... Just wondering why some people have problems and I haven't with 17K on the clock?
MurderInc
Evo X How Tos / Installations
20
Dec 16, 2022 12:05 PM
dac001
Jan 3, 2016 05:05 PM
evodude32
Jul 28, 2011 12:19 PM
Enjoi926
29
May 18, 2010 05:11 AM
992gnt
Jun 7, 2004 09:52 AM
Quick Reply: Signs of a bad front diff?
