BAD Front Differential
Old Feb 20, 2005, 07:02 PM
PHILLY EVO's Avatar
How do you know when your front differental goes. What kind of signs do you get....
Old Feb 20, 2005, 07:56 PM
Crazy4Cars's Avatar
Just remember that the front diff on ours cars is inside the TC.
Old Feb 20, 2005, 09:04 PM
Bom's Evo's Avatar
i thought 03's were open diff?
Old Feb 20, 2005, 09:11 PM
SouthernCrane's Avatar
It is, but it is located in the TC
Old Feb 20, 2005, 10:32 PM
3K
3K's Avatar
Jack up the front wheels so that both are in the air, then spin one tire in any direction and the other wheel should spin in the opposite direction without stopping or binding. If it does then your diff is f*#%ked.
Old Feb 20, 2005, 11:15 PM
platinumspecv's Avatar
Or you will hear a loud howling noise coming from your TC - on or off throttle (car has to be moving). Also if ur in neutral (car has to be moving)
Old Feb 21, 2005, 08:48 AM
EVIL_EVO_VIII's Avatar
What he said. I thought mine was shot and i also did this!
Old Feb 21, 2005, 08:51 AM
matt55's Avatar
did you check ur other thread ?
I'm just trying to find out if my front differental is bad I have a loud bang comming from the front driverside wheel when I turn from left to right and cant figure out what is wrong threre is no whinning..... I love driving in all 4 wheels screw front wheel and honda...
When my front diff went out the only thing i could see was that drivers iner cv boot came off , which i found out later that a effect of the diff crapping out . When i truned the wheel right or left it made a loud "POP" and moved the sterring wheel . What you should do is put ur car in gear , jack up the front , trun the drive wheels with your hands back and forth . if the diff is bad the other front wheel will not trun or trun and stop and make a griding sound . hopes this helps ,this is how i found out what wrong with my car , btw it ant cheap to fix !
__________________
Old Apr 5, 2015, 09:44 PM
charliesky32's Avatar
Ff
Old Apr 6, 2015, 04:18 PM
suby2evo's Avatar
Bump! I also would like to know this!
Dross99_si
May 14, 2016 09:36 AM
deadstockkpomp
51
May 9, 2013 02:13 PM
camillejorge8
Jan 11, 2011 05:58 PM
badev0
Jun 4, 2010 04:21 AM
seancar408
Jan 31, 2009 04:04 PM
Quick Reply: BAD Front Differential
